					Originally Posted by  356Guy
				My amp isn't getting power among a few other issues.  I went through the pin outs and diagrams.  I'm pretty sure that I have the wrong harness.  The simple harness can't possibly work with my sound system.   If I look at the current wiring and the Continental and Becker diagrams I see the problem:
- My current wiring does not use the B block (apparently this is unused in HiFi option/Nokia cars)
-     My current wiring uses the C block pins to send the signals to the amp; the Continental diagram doesn't show that the C block pins are used for anything other than the C4 and C6 pins for SWRC.
-     The only output to the amp on the Continental is the B block which explains why I have no sound because it is not being used
-     I therefore need a harness that goes from the Continental B block to the existing harness C1 block.  Do I also need a line-out converter (LOC)?
-     Also, there is no ground pin in the Continental head B block.  Does my amp need that?
-     Reference https://rennlist.com/forums/993-forum/896189-installing-the-continental-tr7412ub-or-radio-6.html
If the above is correct then the other/M490 harness should work. This is what it is supposed to do:
    Swap of Terminal 86s and 30 pins (switched and permanent 12V)
    Wire for connection to Nokia/Bose amplifier power on circuit
    Line Output Converter (LOC) for connection to existing amplifier
Looking at the picture it looks it is exactly what I need.  It also means that not having option code M490 does not necessarily mean that the simple harness will work.
What stereo option do you have?  Which amp does your car have?
