Old 06-04-2017, 10:20 AM   #1
BYprodriver
BYprodriver's Avatar
Originally Posted by perspectivism View Post
Hi I believe I spotted it early. Right after I heard the voice I had the car towed to the mechanic.
Sent from my SM-G930F using Tapatalk
Sounds like your mechanic did a good repair, BUT the cause MAY have been a leaking fuel injector washing oil from the cylinder wall causing the piston to crack. Recommend you remove the fuel injectors & have them pressure cleaned & tested before reinstalling, or the problem may happen again.
