Old 06-04-2017, 08:13 AM   #19
Gilles
Originally Posted by oldskool73 View Post
Also have a 97 base with just over 105k KM, still on original water pump (maybe they made them tougher back then?), just had original flat topped AOS changed out as preventative. Had a new clutch put in when I got it about 15k ago, did LN IMS upgrade at the same time for 'new owner peace of mind', though it probably didn't need it. Still going strong... fingers crossed...
62k miles on the original water pump… you may want to consider replace it before it fails (with potentially expensive collateral damage)
The O2 pumps are considered a wear item and I believe that Porsche recommends it changing it around 40k miles (?)
My car has 99k and is already on it's third pump
Gilles is offline   Reply With Quote
