Researched Temps
Thanks for the comments. I did a lot more research and found that most tranny temp gages have 180 Degrees F as the center point and thermal switch options are 180 or 190 degrees. My tranny cooler has a driver operated On/Off switch but no temp gage to tell you what the temp is. So I am adding a 180 thermal switch to turn on the pump as well as an indicator light to show when the pump is on. Next step is to figure out how to interface a tranny temp sensor to my AIM Dash and try to get a temp read out there. Worse case add an Autometer Tranny temp gage. Thanks
