Old 06-03-2017, 12:09 PM   #15
soxfan1966
That is/was the purge/bleed quick disconnect from the oil/water exchanger to the coolant tank that has failed. The barbed piece is inside the other hose. I would not re use that fitting since it has already failed once. Of course the proper repair would be to replace the fitting using the correct part. However in the interim you can get a 1/4 or 3/16" brass barbed connector (take the fitting to compare) at auto parts or Lowes etc and join together. You will then need to properly purge the system of air.
I reached the same conclusion when I tried using that same piece. Fished the broken end out of the other hose. On way to get a brass hose connector and some hose clamps now.
soxfan1966 is offline   Reply With Quote
