Old 06-03-2017, 08:22 AM   #5
dav9515
Where is the car located? your profile says Virgina, the title says Oregon/Seattle, and your phone number says Connecticut?
Also, was the IMS bearing replaced with an aftermarket solution? if porsche replaced the motor the one they put in has the same IMS bearing as all the rest so it would suffer from the same rate of failure correct? Thanks
dav9515 is offline   Reply With Quote
