Originally Posted by 911monty
Tried pulling the end bushings and re greasing yet? Could be dry and adjusted too tight since there is no spring assist built into the shifter. Most likely just dry. I pulled mine and also re greased the bearings in the lever assembly. Like new now.
I have not. Should have the car back by Monday - I'll take a look at it when I get the car back. Thanks for the tip.
