Originally Posted by 78F350
Does everything else function well with the shifter? Thumb button/locking position in park/seating in (D)? Check the shifting cable on the transmission end. Make sure it is securely mounted. I'd also get a look at the transmission mounts and engine mount to see if they are worn out.
I agree with this . When mine started having trouble going into park my indy started at the lever on the trans. Now I`m not saying for anyone to do this but. We put it on the hoist with me inside. Once up where he could see it we went through the gears. The lever mechanism was dirty and corroded and wasn`t moving all the way. He cleaned it with emory paper and it worked fine.
