Originally Posted by rastta
Thanks - I was thinking B&M based on photos but could be a knockoff as well. I'll be honest - I don't like it much. It could be just worn out - but it has no real spring "side" assist which makes it dicey going from 2-3. Have to make very deliberate shifts or I'll wind up in 5th.
Tried pulling the end bushings and re greasing yet? Could be dry and adjusted too tight since there is no spring assist built into the shifter. Most likely just dry. I pulled mine and also re greased the bearings in the lever assembly. Like new now.
