Thread: Vibration
Old 06-01-2017, 01:53 PM   #23
AZ986S
AZ986S's Avatar
Well today I went back to the tire and wheel shop to have the wheels checked again for out of balance. I've been battling the same vibration issue at 70 mph and higher.
The shop says all 4 wheels roadforced balanced less than 10 lbs and all is good as far as the wheels are concerned. So that leads me to believe that the suspension or steering is the culprit. Since I've observed no slop in the steering at all, and it is very crisp, I believe the LCA bushings or balljoints must be worn.
I have not replaced any suspension components other than the rear shocks after I bought the car last year. Front shocks rebound fine, no leaks. LCAs look old. Any way to tell for sure? If I do LCAs, should I also do the track arms?
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
