Old 06-01-2017, 10:21 AM   #11
Vidyashankara
Originally Posted by paulofto View Post
Save time, effort and a lot of potential alignment issues and drill an 2" diameter access hole in the tray. You'll be happy you did.
To remove just a little fluid, remove the fill plug and jack up the from end, some fluid will leak out the fill hole and then level the car and see if the 11 mm difference is met.
Awesome, thanks! Can you explain the potential alignment issues?
The hole will give access only to the drain plug right? I am not sure if i can access the fill plug without remove the tray.
Vidyashankara is offline   Reply With Quote
