Old 05-29-2017, 07:52 PM   #2
rick3000
There Is No Substitute.
rick3000's Avatar
If you are just getting steam around the cap, and on the trunk lid above the cap, replace the cap, it is a common point of failure. I would also ensure that the coolant tank is not overfilled. If it is not just steam, look for white residue around the coolant tank, the OEM fluid leaves it behind to help identify leaks. Also try reaching under the carpet near the tank to see if it is wet.
rick3000 is online now   Reply With Quote
