Old 05-29-2017, 10:12 AM   #3
rick3000
There Is No Substitute.
rick3000's Avatar
Thanks Gelbster, that link is helpful! Hopefully someone will create a comprehensive guide to help everyone get the most of the Durametric. I used a few pages pulled from the 986 Service Manual Diagnostic section that lists what the actual values should be, but there is no explanation of what the values mean or what slightly higher or lower values indicate (plus I don't like using likely outdated info pulled from the pdf service manuals). I was going to try and compile a guide, but there simply isn't much information out there about a lot of these things, and if there is it tends to be really technical.
