Old 05-29-2017, 09:22 AM   #6
dghii
The creaking noise is typically caused by the lower control arm, coffin arm. The easy fix is to make a very small hole in the lower control arm ball joint rubber cover. Then inject either WD-40, grease or silicone into their, depending on your choice. The Fixx can last for a week or months, but it's not permanent. And by the way, the creek does not mean that the ball joint is bad period
But I agree with the sentiments of those above, you should shake down the entire suspension once you have it up in the air.
I've done this on my car as a 'nothing to lose' situation. Been a couple of years and no noise since. I think I shot a little lithium grease in the boot instead of WD40 but either way will at least allow you to troubleshoot the source of the noise.
dghii is online now   Reply With Quote
