Old 05-29-2017, 08:22 AM   #12
dghii
The creaking noise is typically caused by the lower control arm, coffin arm. The easy fix is to make a very small hole in the lower control arm ball joint rubber cover. Then inject either WD-40, grease or silicone into their, depending on your choice. The Fixx can last for a week or months, but it's not permanent. And by the way, the creek does not mean that the ball joint is bad period
But I agree with the sentiments of those above, you should shake down the entire suspension once you have it up in the air.
I've done this on my car as a 'nothing to lose' situation. Been a couple of years and no noise since. I think I shot a little lithium grease in the boot instead of WD40 but either way will at least allow you to troubleshoot the source of the noise.
