Old 05-29-2017, 05:48 AM   #271
itsnotanova
The few scales like these that I've put both my Boxster and Carrera on where both about 125 lbs more then I expected. I last one was 3170 and 3240 respectively. The owner of one said theirs shows about 100 to 150 more then the actually weight and all they care about is the before and after weight and even this can be off +/- 5 lbs since it weighs in 10 lbs increments. I think you can probably knock off 75 lbs and have a pretty accurate number.
Thanks for the info. I've seen some races have tech inspection with scales set up and I'm thinking I'll try and sneak onto one when I get a chance.
Woody
