Old 05-28-2017, 12:15 PM   #17
DarkStar
DarkStar's Avatar
Do you have any trouble with your windows dropping and going back.up when you open and close the doors? If so maybe the door lock microswitch has failed in the "door open" position and the computer thinks your doors are open all the time, which could explain the interior lights staying on all the time?
No. Minus being a lil slow on opening the door fast. But thats probably just me opening the door super fast. Other than that there are no issues here. The window moves up when door is closed and down when door is open.
The small dome light LED and frunk/trunk latch lights (among other things) are powered by the "consumer switched off" circuit. This circuit stays active for a while after the ignition is shut off to allow use of certain functions while the car is off (like power mirrors, seats, etc). Reports on the length of time that this circuit stays active are conflicting with some saying as little as 3 minutes and others saying as much as 3 hours.
Can you confirm that the dome LED never shuts off, even after sitting overnight for 8+ hours?
Opening a door reactivates the circuit, so Steve may be on to something.
However, it would take roughly 100 LEDs to draw 2.6 amps.
There are about that many between the 986.2 gauge cluster, climate control and switches...
I cannot confirm the time yet. Lets see, the pictures I took yesterday were maybe an hour or 2 after locking the doors. I just know I've noticed it in my security camera's that have night vision that it looks like the entire cab is lit up. I can check this tonight as I've already opened the doors and fired up the car today to get some charge in there since I'll be playing with it soon. I do know that feature when you shut off the key and pull it, the windows and what not can move. But usually this stops when the door is opened. I think. I did open my door last night and without turning the key on I was able to roll the seat back.
But I do agree that, these LED's are not drawing that much amperage. The window/heated seats led's are hardly noticeable but if you look hard at the pic you can see them lightly glowing. The led's that pop the trunks is lit up all the way.
I'll get more info tonight. But will start the testing of those fuseable links now.
-Josh
2001 Porsche 986 Boxster RS2.7 Bi-Turbo
DarkStar is offline   Reply With Quote
