Analysis fail. You'll want to maximize the area under the horsepower curve. When you have the dyno plots (hp / torque vs rpm for range) like you do, you can essentially ignore torque vs rpm for this exercise.
If you are upshifting (in any gear) before even reaching the horsepower peak at ~6200 rpm, you're definitely upshifting too early.
2001 Boxster
