Old 05-25-2017, 02:57 PM   #1
KevinH1990
KevinH1990's Avatar
Search on "ignition switch" and see if anyone else reported similar symptoms when their switch failed. It is a pretty common problem area. I don't have a tip, but I assume that there is some kind of interlock with the brake peddle or gear selector that prevents you from starting it in drive or reverse. That may be another source of the problem.
