Old 05-25-2017, 09:49 AM   #18
The Radium King
The Radium King's Avatar
most track pads don't come with openings for the sensors. further, at the track you should be visually inspecting your brakes, not waiting for a light to come on. finally, heat from track use can cause the sensors to fail prematurely.
soln? snip the wires just short of the plug and twist them together. ecu sees continuity and assumes all is good.
