The easy part is to inspect all the visible rubber for cracking or missing pieces. After that it gets a lot harder. I just replaced my rear trailing arms and you couldn't see any problem with them, even after removing them. The ball joint seems tight. But when driving the ball joints would rattle every time I went over a big bump.
It also takes a lot of effort to shake the suspension because its so stiff.
1941 Dodge Luxury Liner Coupe
