Old 05-23-2017, 02:55 PM   #1
RedTele58
RedTele58's Avatar
Originally Posted by Xpit77 View Post
Sometimes the dip stick tube breaks. The stick will go out the opening instead of going to were it is suppose to. This will show no oil.
^^^ This
This happened this past summer to 78F350 (Jon) when he rescued the car that is now my Spec Boxster build. His solution after adding oil and it not showing on the dipstick was to check the dash display with the ignition turned to the first position. It showed full, and sure enough, he had to drain oil from the engine prior to starting.
Check the dash display before you go too far down the rabbit hole.
