Anker, are these calipers made from aluminum or steel? If steel, you could put some heat on it and then the easy out will get the broken bleeder out. But the caliper will have to be repainted at a minimum, and maybe rebuilt too. We used to do that on MG's, Triumphs, Austin-Healeys, etc which had steel calipers, couldn't do it on Fiat 124s which had aluminum calipers.
