Old 05-22-2017, 08:58 AM   #23
rick3000
There Is No Substitute.
rick3000's Avatar
I use a long/low HF floor jack which I really like, not everything from HF is garage.
I also have 4 Esco 10498 stands, and I would highly recommend them if you want something a little more versatile than model specific lift bars. They are very stable, and I really like the tripod base because I can slip a few 2x4 scraps or bricks under the jack stand post as a backup. I never understood how anyone could trust those dinky aluminum tube stands with a 6" circular base from pepboys. I would never get under a car without good stands. If I have the wheels off I will lay them under the rotors as another backup.
I have never used ramps, I don't think they are the best option for the Boxster. It is too low to the ground, so you would need really long ramps. Plus, if you only lift the front or back the car won't be level, so you won't be able to drain all of the oil, or other fluids.
