Old 05-22-2017, 09:52 AM   #26
particlewave
There are 5 switches in the door latch, so any one or more could be bad. Hard to say.
I would talk to Woody and see about getting a replacement. If it doesn't fix the issue, maybe he will take a return. Couldn't hurt to ask him.
You should probably check the easy things first, like checking for corrosion on the pins of the door harness connectors (both inside the door and the primary connector near the door hinge).
