Old 05-20-2017, 02:04 AM   #1
oldskool73
oldskool73's Avatar
So you've changed over the transmissions, but not updated any of the wiring or swapped to the newer relay, right?
You know in the old system there's 2 inputs, one from the lever at the rear, and one from the microswitch near the top mounting/pivot point on the drivers side. Did you maybe have the top open or in the service position when you tried closing it so it wasn't hitting this switch?
oldskool73 is offline   Reply With Quote
