Old 05-19-2017, 12:51 PM   #14
Oldcarguy
Oldcarguy's Avatar
Originally Posted by pidj View Post
The Quick jack will put it up high enough to use a creeper, and still do stuff?
per QJ docs the maximum lifting height is 17", 18" & 18.5" for the 3500, 5000 & 7000 respectively with the small rubber blocks (all you can use with the 986 I believe). For my Explo & QJ 7000 I can get approx 21" of lift with the SUV stands. Best to check the QJ website for detailed info on the lifting block and SUV stand options.
Just a suggestion, don't buy the 7000 unless you really need it. The 7000 lifts are wider and significantly heavier than the 5000 and 3500.
Rgds, Fred
