Old 08-01-2006, 12:58 PM   #15
rodsnhawgs
rms r & r
A few items worth noting. Apparently Porsche uses two different size fasteners on the inboard half-shaft hubs. The dealer tech cautioned me (and I you) to be sure to torque these to the correct specs. On the tiptronic cars, the starter must be removed to access the torque converter bolts - be sure to use a suitable retainer, as shown in the Bentley, on the torque converter so it doesn't fall out when removing the transmission. I also stuffed a rag in the starter/trans opening so I wouldn't drop a torque converter bolt down in the trans bellhousing when going in or out with these bolts. I had all the parts in-hand before I started so as to avoid untimely delays.
One other thing that bears noting. I didn't use the go/no-go tool to measure the opening. I didn't use the Porsche seal installation tool either. Because I've worked on cars most of my life, and have a good selection of tools and measuring devices I was able to do this without these specialized tools. Use your own judgement as to your abilities. Be honest with yourself - you may want to opt for these tools - again, probably a good investment.
So far, so good...as noted below, total parts cost was less than $150 US. If you attempt this yourself, go slow, refer to the good folks here and on other sites often, and be safe.
02 boxster
chopped 48 Chev pickup (under construction)
99 Harley Road King
04 Honda Element
07 Nissan Murano
rodsnhawgs is offline   Reply With Quote
