Old 08-01-2006, 11:52 AM   #12
rodsnhawgs
rms r & r
As promised, here's a few pics in successive threads. I'll make a few comments along w/ the pics. Also, refer to the links that are noted/notable resources. There are others on the "net", but these are a couple of really good ones.
First, let me say that even though this could be a "driveway" job, as you'll see from the pics, my shop is well equipped which made it much easier and safer. Second, this job is not beyond the capabilities of any of you with a decent level of mechanical aptitude and most basic hand tools. You may need to buy, borrow, or rent a few tools, but the offset in labor saved would be well worth the investment in my opinion. OK, let's get to it:
The Bentley Svc manual shows an engine support tool to "hang" the engine from while the transmission is removed. This is because the downward forces on the engine/trans are supported by the (transmission) rear mounts. Anyway, I made the same rig out of a 2X4, a piece of allthread , and a short section of chain (see pic). This allows for adjustment up/down and support w/ the trans removed. The other pic shows the car on the rack w/ rear supported on jack stands so the wheels and axles can turn.
02 boxster
chopped 48 Chev pickup (under construction)
99 Harley Road King
04 Honda Element
07 Nissan Murano
rodsnhawgs is offline   Reply With Quote
