Thread: IMS tell tale
Old 05-12-2017, 02:01 PM   #15
JFP in PA
In theory (covered in another JFP thread) you can use Durametric deviation readings (bouncing line) to observe the effect of a worn/wobbling IMSB. How much warning you get with this I don't know. But it helps make the case for using your Durametric every time you change oil or even more frequently to develop a history and familiarity with this tool. And getting a filter slitter if you have a spin-on.
We have only seen a very small handful of cars do this, and quite plainly it was a moot point anyway, as further examination showed the filter and sump full of ferrous grit, eliminating the chance of a retrofit without a full rebuild.
