Old 05-11-2017, 12:21 PM   #19
JFP in PA
if i read JFP right, he meant that option 1 is replacing the whole valve assembly (part 11 in the diagram) Vs replacing only the O-Ring (part 9)
i wouldn't go and replace the whole tank if it is not leaking.
very expensive part, and very hard to replace.
You are correct. More often than not, trying to repair that valve or replace the O-rings comes to grief. So while replacing it may not be the cheapest approach, it is the one with the least chance of coming back to haunt you.
