Old 05-10-2017, 03:25 PM   #2
AZ986S
AZ986S's Avatar
I don't think the clutch and brakes are related, but to me this sounds like a vacuum leak to your brake booster, or booster is leaking. Had the same issue in another vehicle.
Higher RPM replenishes the vacuum level, but use + low RPM and vacuum is gone.
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
