Buttoned up the maintenance activity and got the car running - went for a test drive. All good! Quite a lot done on this "new to me" 40k mile 2001S with "some issues" that I purchased from a friend. Most of it was uneventful, except for separating the headers from the secondary cats and a single header bolt that broke off in the head and I had to put in a time-sert.
Replace Oil Fill Tubes (leaking)
Replace AOS (PM)
Replace RMS (leaking)
Replace IMS (LN Single Row Pro)
Replace Plugs and Coils 997 version (PM)
Oil & Filter Change
Air Filter
Climate Filter
Fuel Filter
Water Pump, Hoses & Coolant (PM)
Belt Replacement (PM)
Clutch, Pressure Place, TO bearing (PM & WIWIT)
Stainless Brake Flex Lines (PM)
Brake Fluid Flush (PM)
Replaced Undertray rubber cooling scoops (repair)
Wheel Stud Conversion (usability)
New Wiper Blades (PM)
Secondary Cat Bypass Tubes (fun factor)
Convert Exhaust Bolts to Stainless Studs (usability)
