Old 05-09-2017, 04:19 PM   #3
AZ986S
AZ986S's Avatar
Thanks JayG.
My ashtray cover doesn't close I will convert it to a storage bin this summer.
Funny you mention banging the rev limiter, since I just went through an issue where during the last DE, I got distracted in 2nd passing someone and forgot to shift so it went up to 7,600 RPM before I shifted into 3rd. After the event, I reviewed the data log file to confirm this happened and it did. I went back to the shop that tuned my car (Vivid Racing) to explain to them that this should not happen (that is why there is a rev limiter, I did not ask to remove the rev limiter). They re-flashed with a supposedly "good" tune, but I did not "test" the rev limiter on this last outing at AMP since I was very conscious of this and a little shy of the redline... So on a couple of the straightaways, I could probably push it some more in 3rd, but on others, I'm hitting 103 so I would need 4th anyhow, so that is why I shift a little early
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
AZ986S is offline   Reply With Quote
