Old 05-08-2017, 11:16 AM   #11
husker boxster
husker boxster's Avatar
Originally Posted by ExplorerLyon View Post
Airbag lights: Are the airbags a common problem? I looked at a 2001 where the airbag light was on all the time. The used car dealer said they had to remove the passenger seat to fix the seat belt and most not have reconnected everything. I looked at a 2004 where the airbag light did not illuminate at all when I turned the key. Every other light light up fine. Thoughts?
You should always disconnect the battery before unplugging an airbag. If you do not reconnect the seat airbag before reconnecting the battery, the airbag light will come on regardless if the airbag is connected later. The light will either need to be shut off by a dealer or someone with a Durametric tool.
1989 928 S4 5 spd - black
