CV Boot leak
Thanks NewArt.
Upon further investigation, I found that this is a common occurrence for tracked cars.
There is an article here on how to re-pack and re-clamp a boot.
Leaking CV Boots - Repack and Clamp - Articles
Should be able to do this without removing the axle ( I hope  )
2002 Boxster S - NHP 200 Cell Headers,test pipes,Borla CatBack,Competition Plenum,74 mm TB, EVOMS Tune,Tarett UDP,Eibach Swaybars,BIlstein PSS9s,TuneRS rear toe links,wheel studs,15 mm wheel spacers on all 4,EBC yellow stuff pads,Sebro rotors, EBS oil baffles,160 deg Thermostat,2 quart Accusump,full filtration remote oil filter,rad fan switch,custom gauge/switch plate, Race Capture data logging, 90K miles
