In addition to removing the outer seal of the IMS bearing, you can also add the DOF (Direct Oil Feed).
I did this to my 2007 Cayman S (which carries the large bearing) about 3 years ago.
Supplying the bearing with pressurized oil is (debatably) the best thing you can do to keep this bearing from a premature death.
Good luck.
