Old 05-06-2017, 02:38 AM   #26
RichRobby
Originally Posted by grc0456 View Post
Do not use the metal ball socket. These items were made of plastic for a reason - to break if there was undue pressure on the strut - saving you from even worse damage. Buy the aftermarket plastic ones. I suggest buying a few so you have an extra on hand. Also do not operate the convertible top electronically until the socket is replaced - that strut will poke a hole in your foam drip tray.
Good advice, thanks.
Maybe that's why I found a hole in the plastic foam when I first got the car!
Sent from my ONE A2003 using Tapatalk
RichRobby is offline   Reply With Quote
