Old 05-06-2017, 02:18 AM   #25
grc0456
2003 Base 5-speed
grc0456's Avatar
Do not use the metal ball socket. These items were made of plastic for a reason - to break if there was undue pressure on the strut - saving you from even worse damage. Buy the aftermarket plastic ones. I suggest buying a few so you have an extra on hand. Also do not operate the convertible top electronically until the socket is replaced - that strut will poke a hole in your foam drip tray.
