Old 05-05-2017, 09:58 AM   #1
Fintro11
Fintro11's Avatar
Originally Posted by schoir View Post
That strap is supposed to go UNDER the side of the top, so that it can be hooked onto the locating tab on the front of the convertible top frame.
When you are done with it, it gets unhooked and then gets folded over onto itself and be stowed by pressing it onto the velcro section that is located under the rear main bow.
Your other situation (relayed to me by Boxtaboy) with the top binding on the back of the roll bar hoops looks like it may be alleviated by relocating the entire frame a tiny bit back by loosening the 3 bolts on each side of the frame (and one possible phillips head screw).
Regards, Maurice.
Hey Maurice,
Thanks for the info. The problem I am having is the glass window did not want to fold down so the rest of the top started binding against it. Removing the two tabs seems to have fixed it. I'll try take a video it's hard to explain how it binds properly
Fintro11 is online now   Reply With Quote
