They will fit the Box. Rears will be wide stanced (+10mm) the fronts will be the same as stock 18s. I would add a 10mm spacer on the fronts. You can also run 235/40/18s with the spacers. These wheels would look the same as other 18" twists. Their advantage is their reduced weight and consequent reduced inertia.
