Thread: Durametric Help
Old 05-02-2017, 03:24 AM   #1
jeeper31
jeeper31's Avatar
Then you already know why the Durametric doesn't turn it off. No system, even the almighty PIWIS, can permanently turn off a MIL light unless the problem if fixed first. Different systems may turn if off for brief periods, but it will continue to come back as soon as the I/M Readiness monitor mandated by the EPA resets (the I/M monitor is there to prevent people from clearing the codes and trying to squeak by state inspections. Until the monitor cycle is complete, the car would come up as "not ready" and will fail inspection, once the monitor resets, the codes reappear).
Why would an OBD II scanner turn off the check engine light but not the duremetric? On 2 separate occasions I tried to turn it off with duremetric and couldn't and then took an OBD II reader and it shut off the light. He light didn't come back in for a couple of days either so it's not a constant condition. It happens every once in a while, not immediately after the code is cleared.
jeeper31 is offline   Reply With Quote
