Only $9990 - Amazing deal!!
Car: 1997 Porsche 2.5L Boxster with 5 speed manual transmission
Mileage: 80,100 (low miles)
Exterior Color: Silver
Interior color: Red
A/C ice cold
newer soft top with glass window
CA registered, Smog, Clean CA title in hand.
Car is located in Point Loma San Diego, 92106.
If you are serious buyer please call @: 202 four four one 6444. I encourage you to come and see the car.
Videos Links:
1. Complete walkthrough video:
https://youtu.be/8za_1Q7kZ1E
2. Start up and exhaust note Video:
https://youtu.be/CcgdkAwKrlM
3. Take off rear view Video:
https://youtu.be/KdKWhJK0L8Y
4. Front passing-by Video:
https://youtu.be/llHRo87ODEE
This is a newly built street legal track car and a daily driver with newly built track equipment. Only one PCA AX event (testing purposes). 1997 year cars is very robust and a good candidate for a Spec Boxster, you can improve on what I have invested if you want to go in the Spec route. Car has an upgraded exhaust, car has been flashed by previous owner and it is much faster and peppier after than other 986 base models. I bought a different car hence selling.
------------ Useful and cool Options/upgrades ---------------------
- Two collapsible cup holders
- Removable Sound System with remote
- Factory Storage box above engine lid (extremely useful)
- Porsche 986 MK1 Black LED Headlights - these are pretty expensive; I think about over $1000 for the set , please google.
- New tail lights with light smoke
-------- Various Tack/Race Upgrades: ------------------------
- Color matched Porsche factory hard top
- Custom Porsche graphics with numbers (both numbers and stripes can be removed separately).
- Racing decals used by Porsche motorsports
- Brey Krause Boxster Roll Bar Extension
- Interior color matched (Red) COBRA Monaco Pro Racing Seats (Driver and Passenger)
- COBRA FLAP runners, mounts, seat adjustable
- Schroth Profile II 6 point HANS compatible race harnesses both sides
- Momo MOD 78 SUEDE 330 MM Steering Wheel
- MOMO Hub Adaptors
- Porsche Short shifter - very aggressive shifting
- Custom exhaust
- Custom Air intake system
- New Fuel Injectors and Fuel system service - this is an expensive service!!
- New battery
- Wheels: Squared Boxster Spec wheels set up: :Four Porsche turbo twist 17x8.5 50mm (996.362.126.05) rear Porsche Boxster wheels in all four corners painted in mat black.
----------- Maintenance History (service records available) -------------------
4/28/17: All four Oxygen sensors replaced with OME Bosche sensors.
01/02/17: Replaced pedal switches (996-613-113-02, 997-613-109-50)
2/4/2016 - water pump
12/20/2016 : New Fuel Injectors and Fuel system service
7/19/16 :
- Removed and replaced all Fuel Injectors with new Porsche Fuel Injectors and seals
- Replaced pressure regulator.
- Replaced Change-over values for Air injection, Cut off valve for air injection, check valve for crankcase ventilation
8/06/2015
- New alternator and assembly
- New ignition lock
- New ignition switch
7/21/2014:
- Driver belt service
- Hood strut
- under trunk release
Cons:
There is a spot on the back that had been sanded and primed in gray color but not painted but I did' care since the car was built to be a track car. Some scratches on the front bumper.
