The headlamp's female socket connection pushes into a plastic post with a male plug. That plug sometimes comes loose from the post or the post cracks, and therefore won't allow the headlamp socket to connect. Happened to one of my plugs that came loose from the post. I had to buy a new clip to properly reattach the male plug to the post, and then the headlamp connection worked fine. Take the headlamp out, look into the headlamp tray, and you'll see what I'm talking about. If the plug or post in the back presses back with your hand, then you know the problem.
