You could look from inside the fender but it is easier to pull the light out. Remember, litronics have 2 plugs to connect, one should just slide in when the light is placed back but there is another at an angle that need to be inserted manually.
Looking from inside the fender will confirm if the 2 sockets get connected right but removing the liner entails taking your wheel off and removing several expansion rivets and at least one nut.
