Durametric Help
My airbag light is on and I had a check engine light. I was able to scan the DTC codes to find out what was wrong. When I tried to clear the code it gave me a code cleared message but the light didn't shut off. When I scanned the codes again it found the same trouble codes. I am having a misfire in cylinders 1 and 4.
The Duremetric was unable to turn off the check engine light OR the airbag light.
The airbag light came on when I pulled the seat to do the water pump. I did not disconnect the battery first.
Thanks,
Dan
