Old 05-01-2017, 11:36 AM   #11
Craig030774
So, you have the same behavior with the new immobilizer, Craig?
That points to something on the car being wrong. Probably door latch issues. I still think you both have bad door latches (probably on both doors).
Also, the connectors in the door frames are known points of failure. Moisture can get in and corrode the pins/sockets. They can be cleaned with contact cleaner.
yes same issues with new immobiliser not had chance to dig any further with car other than test that I get an earth at clu when turning key for lock/unlock
Craig030774 is offline   Reply With Quote
