Just went thru this too. Oreillys can test on the fly and give you print out whether it's good or bad. In my case both were bad battery/regulator. Many forget that even a close to dead battery can show over 12 Vdc, imagine a thin wire will conduct voltage but it's the Amps that make things happen in cars. Regulator definitely suspect!
