Old 04-28-2017, 10:09 AM   #8
san rensho
Originally Posted by Need_for_speed View Post
My understanding is that this issue begins as a harmless problem that gradually progresses to something you'll be forced to address. Apparently, trace amounts of fuel contaminants will start to build up in the valve and hose and start to cause the whistling noise. Eventually, the buildup will become so adverse as to cause difficulty fueling, hard starting after refueling, as well as triggering various fuel evap system codes. This problem is a bit tricky to diagnose, as there are several components in the fuel evap system that can cause this issue.
It's actually pretty easy to diagnose. All you have to do is pinch off the rubber part of the evap hose right at the throttle body then if the car starts easily there's no Whistling noise and if it is easy to fill the gas tank, then it's probably the EVAP valve.
Current car
2000 Boxster 2.7l red/black
Previous cars
1973 Opel Manta
1969(?) Fiat 850 Convertible
1979 Lancia Beta Coupe
1981 Alfa Romeo GTV 6
1985 Alfa Romeo Graduate
1985 Porsche 944
1989 Porsche 944
1981 Triumph TR7
1989 (?) Alfa Romeo Milano
1993 Saab 9000
