Old 04-26-2017, 06:32 PM   #10
Heiko
Heiko's Avatar
Originally Posted by rczap View Post
Heiko here is a picture of the radio with the serial number shown. Not sure what else I can do.
Sent from my SM-G920V using Tapatalk
Man there has to be something wrong with this thing...
The two codes I gave you are the two codes i get, I just ran them again for that serial just to be sure and 9947, 9945 are it.
Now I have seen the serial number display in error if the display is damaged. So for instance if the 5 was a 6 or the 9 was an 8 etc...
you can try 9643 as a third alternate but chances are slim that it will work. If you happen to question the display the only other option is to pull the unit out and read the etched serial on the side of it. I'm not sure what else to tell you....
Heiko
https://greatcyclechallenge.ca/Riders/HeikoVoss
Previously owned:
